Mantels and Surrounds Wooden and Stone
It is difficult to describe a more comfortable aspect in a home than a fireplace. When renovating, wooden mantels with stone surrounds are a perfect match which makes fireplaces into classical centrepieces that are both safe and sturdy.
Mantels of wood are usually made of oak, walnut or reclaimed timber and add character and the aspect of craftsmanship. Their grains and finishes are also customized to suit various styles; that is, rustic, traditional or modern. Stone surrounds are used to enclose the fire with the use of granite, limestone, or slate. The stone is heat resistant, safe and it forms a natural background to match the wood above.
This is a good combination in renovation projects in the living room, dining room or even bedroom where mood is a concern. Rough stone fireplace and simple timber mantel gives one a sense of a farmhouse. In the meantime, a smooth marble enclosure with a smooth wood mantel can be used in modern rooms. It is not only more aesthetical but also makes the fireplace a durable and useful element.
Conclusion:
The ideal combination of old-fashion and functionality is represented by wooden mantel fireplaces with a stone surround. Wood brings in coziness and vulnerability whereas stone brings in stability and durability. Their combination forms welcoming areas that attract an individual and remain timeless. To the renovators, this mix will make the fireplace the center of the house both physically and in its use.
Love the designing .
This is really insightful
You are always on point buddy
This is a valuable read.
This is so straight to the point
I love how the design came out
Nice renovation article
The image says it all friend…
This is really valuable
