A hacky and stacky house often shows a patchwork of mis-matched, substandard or improvised materials. From flimsy wallboards to weak roofing sheets, and hollow interior doors, such materials may have been selected for quick fixes, or cost savings. While these solutions may have proven to be effective on a temporary basis, they are rarely sustainable over time. For a renovation to be truly successful, a material quality cheque is extremely important.
The first step is determining what materials can be salvaged and which ones need to be replaced. Sometimes in older houses there may be good timber or strong stone that just needs to be restored, but newer additions are likely to be poorly constructed with substandard materials. Careful inspections are made to ensure no weak or unsafe components are missed.
Replacement should be importance of durability and longevity. High-quality lumber, weather-resistant roofing, treated insulation, moisture-proof drywall are just a few examples of upgrades to ensure the house can withstand the stress of daily use and environmental stress. Using quality materials not only makes it safer but also means less frequent repairs and thus saves costs in the long run.
Equally important is consistency - using matching finishes and reliable materials gives a unified and professional appearance instead of a patchy look. This helps in transforming a house from a clutter instead of an actual build into a solid build.
Conclusion:
Renovating a hacky and stacky house is a chance to make temporary fixes permanent. By carefully evaluating and improving material quality, renovators improve not only safety, but also durability. The result is a house that not only looks better but that stands the test of time for decades to come.
