Minimalism is one such philosophy that has been one of the most impactful design philosophies in contemporary renovation. At its application to staging, it focuses on simplicity, clarity, and functionality, and lets the revised aspects of a property to be in the limelight rather than be overshadowed by the use of too much decoration.
In a barebone staging technique, all objects are not in vain. Rather than crowding rooms with heavy pieces of furniture, renovators choose clean-lined furniture that brings out openness and flow. An example of this is a living room which can have a smooth couch, a plain coffee table and a single piece of art work upon that so that new flooring or architectural elements can shine through.
The color schemes are generally neutral, mostly whites, grays, soft beige, but there are muted accents. This provides a soothing setting that has the power to be timeless and attractive to a large group of purchasers. Maximizing natural light and maintaining clear or using sheer curtains on the windows are also used to add spaciousness.
Minimalist staging is also concerned with storage. The concealed storage areas, in-built shelving, and empty surfaces reveal that simplicity may even prove to be functional. The use of plants or a single item, e.g. a sculptural lamp can be done sparingly and provide a warm effect without disrupting the clean look.
Minimalist staging would lend itself well to any renovated space with an open floor plan, modern finishes, or architectural features, as there is no chance that anything will be competing with the craftsmanship.
In conclusion: Minimalism in staging in renovation is based on simplicity, balance and functionality. By designing clean and airy spaces, refurbishers are able to introduce houses that are modern, spacious, and easily habitable which is the same approach that appeals to the current customers.
