Mirrored glass is also one of the best interior design materials to use to create the illusion of space and light. It is reflected on the surroundings, visually stretching rooms, even a small interior making them look even bigger and open. This design aspect is not only functional but it also gives it a bit of glamour and sophistication.
In bedrooms and living rooms, natural light can be reflected by mirrored glass panels that can be used as wall coverings in dark corners. Mirrored backsplashes make dining areas look deeper and classier whereas full-length mirrored panels make hallways not to feel restricted.
Mirrored glass furniture like a coffee table, a cabinet or a wardrobe is reflective without overwhelming the interior decor. These works are an upscale touch to the room and increase the brightness of the room. Also, wardrobe mirrored doors are advantageous and fashionable with an added dual purpose of storage and space expansion.
Practically, mirrored glass needs to be washed frequently in order to keep it shiny but in the contemporary times smudges and fingerprints can be reduced through treatment. Ornamental changes, like tinted or antique finish, give distinct appearances and the designers are able to adjust the reflective quality to suit the traditional, modern or eclectic style.
Finally, the reflective surface is more than a mirror of glass, which is an element of design. It helps to lighten up interiors, make them more spacious and gives them the layers of elegance and sophistication.
