🚿 Moisture-Proofing Tips for Kitchens & Bathrooms
Kitchens and bathrooms get really wet, which can cause mold, peeling, or damage if you’re not careful. Here’s how to keep them dry:
:droplet: Moisture-Proofing Tips
  1. Seal things up:
Use paint that resists water on walls.
Use boards that resist water in the bathroom instead of normal ones.
  1. Get air flowing:
Put in a fan to suck up steam after showers or when you cook.
Open windows to let air move around.
  1. Take care of tile:
Use tile for walls and floors.
Seal grout lines, so water can’t get through.
  1. Guard wood:
Use cabinets with a coating in wet areas.
Clean up spills fast, so things don’t swell or bend.
  1. Check pipes:
Look for leaks under sinks.
Fix drips right away.
  1. Extra steps:
Put a waterproof layer under tiles.
Use barriers against moisture in walls, especially in bathrooms.
:white_check_mark: In short:
Keeping things dry isn’t about spending lots of money. Use good stuff, let air flow, and keep an eye on things. Then your kitchen and bathroom will last!
This is really informative
Good one putting this out.
Glad you understand every bit of it
Yeah just thought this out
Thanks for providing this this tips
A lot of people Overlook this at home
Thanks for this boss
You are welcome brotherly :ok_hand:
this is very useful thank you for sharing this
You are welcome Boss :sign_of_the_horns::sign_of_the_horns::sign_of_the_horns:
Well written mate, good job
Thank you brother :1st_place_medal: :folded_hands:
Your articles are always superb mate
Thank you very much brother
Thanks sharing this buddy appreciate
This is really good work man
