Monitoring and O&M: is there tile- or string-level fault isolation available to homeowners/contractors, and what are standard diagnostic timelines and SLAs when yield drops?
With a Tesla Solar Roof, you only get data on the string level, not tile by tile. Even that data isn’t in the main app. So, if things aren’t working as well as they should, you’re counting on Tesla to spot it and do something about it. Fixing it means testing the wiring and maybe swapping out parts. The thing is, getting support can take a while. There’s no set time frame for repairs, which means some folks have to wait weeks before anyone does anything. If you want to check your system, give me a shout. I can show you cool tools like Powerwall Dashboard or NetZero to monitor it better.
Yes, panel- or string-level fault isolation is available but depends on your system:
Microinverters or optimizers (e.g., Enphase, SolarEdge) offer panel-level monitoring and fast remote diagnostics.
String-level systems only isolate faults to a group of panels; deeper testing is needed on-site.
Diagnostic timelines vary:
Some faults are pinpointed remotely and resolved in a few days.
More complex issues (e.g., moisture-triggered insulation faults) may take 1–3 weeks and multiple visits.
Best O&M setups use panel-level monitoring with clear SLAs on response time, fault isolation, and repair.
Monitoring and Operations & Maintenance (O&M) for solar panels involve detecting and isolating faults to minimize energy losses.
Fault Detection and Isolation
- String-level fault isolation: Some methods can detect faults at the string level, allowing for quicker identification of issues. This approach analyzes the Voc-Isc curves to identify potential faults.
- Tile-level fault isolation: While less common, some advanced methods can detect faults at the individual panel level, enabling precise identification and repair.
- Predictive fault diagnosis: Certain techniques use machine learning and statistical analysis to predict faults before they occur, enabling proactive maintenance.
Diagnostic Timelines and SLAs
- Fault detection time: Advanced methods can detect faults in under 9 seconds, with some achieving detection times of just a few seconds.
- Diagnostic accuracy: Some methods boast diagnostic accuracy rates of over 90%, reducing error rates by up to 30% under dynamic conditions.
- SLAs (Service Level Agreements): Standard SLAs for solar panel monitoring and O&M vary depending on the provider and system specifics. Typically, response times range from a few hours to a few days, with resolution times varying accordingly.
Most systems offer string-level monitoring to homeowners and contractors, but true tile-level fault isolation is typically reserved for manufacturer service teams.
Diagnostic timelines vary, but SLAs often target remote fault confirmation within a few business days and on-site repairs within 1–3 weeks, depending on parts availability and crew scheduling.
