One of my first renovation projects was replacing a bathroom vanity. I measured the width but forgot to check if the floor was level. Once I installed the new vanity, it rocked back and forth and cracked under pressure. I had to pull it out, shim the floor, and reinstall it. It was a stressful lesson but now I always check level surfaces before installing anything heavy. Sometimes the little details matter more than the big ones.
Most people actually make this mistake though
Hahaha you’ve learn after this
Mistakes do happen, just make sure it doesn’t repeat itself
Happy you learnt your mistake tho
A lot of people ignore the little matter not knowing it counts
At least I’ll have to avoid this mistake
Lol, I’m a victim of this mistake
Thanks for sharing your experience
We can all leave from that
Lessons learnt thank you
Making mistakes isn’t all bad
you just learn something new
Thanks very much for this
Most people make mistakes tho but they will probably learn from that.
I’m glad to see this buddy
