New fridge makes ice that tastes like dirt—what’s causing it?
Ice may appear crystal clear, yet it carries an unpleasant taste reminiscent of dirt or soil. The source of this issue often stems from the water line, which initially connects through a saddle valve. What specific contaminants or materials could be responsible for this earthy flavor, and what effective methods can be employed to eliminate this undesirable taste from the ice?
The earthy taste likely comes from minerals, sediment, or biofilm buildup in the saddle valve line. Replace the valve with a proper connection, flush the line, and install or replace a carbon filter. Regular cleaning of the ice maker and using filtered water can fully eliminate the off-flavor.
That dirt taste in your ice? It’s probs from nature or your pipes. Swap out iffy parts, get better tubes, and toss in filters (like activated carbon or a biofilter) to clean it up before freezing.
Probably from the water line, make sure you’re water source is clean, clean your pipes, clean your pridge and and it should be solved
That earthy taste usually comes from impurities in the water supply, new plumbing lines, or a dirty water filter.
In new fridges, the first batches of ice often pick up residue from manufacturing or the water lines, so flushing the system and replacing or rinsing the filter usually fixes it.
It’s usually from unflushed filters, new water lines, or sediment in the supply. Flush several gallons of water, discard first ice batches, clean the bin, and check the water line.
The earthy taste likely comes from sediment, mineral buildup, or bacterial biofilm in the saddle valve and water line often due to corrosion, stagnant water, or degraded rubber/plastic components.
Replacing the saddle valve with a full-port shutoff, flush or replace the water line, and install a high-quality inline or refrigerator water filter to remove sediments and organic compounds will definitely eliminate the undesirable taste from the ice.
There are several reasons why your new fridge might be producing ice that tastes like dirt.
  1. Dirty or Expired Water Filter: A clogged or dirty water filter can’t remove impurities from the water properly, leading to bad-tasting ice. Try replacing the filter every six months.
  2. New Fridge Residue: New fridges can have residual chemicals or impurities in the water lines, which can affect the taste of the ice. Flushing out the water lines by running water through the ice maker for several minutes might help.
  3. Mineral Buildup: High mineral content in your tap water can give ice a weird or metallic taste. Consider using filtered water to make ice.
