A squeaky or noisy door is a small issue that can quickly become annoying. Luckily, fixing it is one of the simplest DIY tasks you can do. All it takes is a few household items and a little time.
What You Will Need
Lubricant such as WD-40 or even cooking oil, a screwdriver, and a cloth.
Step One: Identify the Noise
Open and close the door slowly to pinpoint where the squeak is coming from. Most of the time it is the hinges.
Step Two: Apply Lubricant
Spray or apply a small amount of lubricant directly on the hinges. If you do not have WD-40, a drop of olive oil or petroleum jelly can work in a pinch.
Step Three: Work the Door
Open and close the door several times so the lubricant spreads evenly. Wipe away any excess with a cloth.
Step Four: Tighten Loose Screws
If the noise persists, check for loose screws on the hinges. Tighten them with a screwdriver to keep the door firmly in place.
Fixing a noisy door takes only a few minutes but makes a big difference in how comfortable your home feels. By applying a little lubricant and tightening loose screws, you can restore peace and quiet without calling a handyman.
