Open concept on renovation
Can I safely remove a wall between my kitchen and living room?
Yes,if you get a good renovator
No, I don’t this it is safe
Yup!
If you are with a professional or rather a contractor
Yeah, get a good worker for that
Removing a wall between a kitchen and living room can be a significant structural change, so it’s crucial to determine if it’s a load-bearing wall first.
If it is, you’ll need professional help to ensure structural integrity, potentially involving beams and permits.
If it’s not load-bearing, the process is simpler, but you still need to consider aesthetics and any potential building code implications
Removing a wall between a kitchen and living room can be done safely, but it’s crucial to determine if it’s a load-bearing wall. If it is, you’ll need professional help to ensure structural integrity with proper support systems like beams or pillars.
Thanks for sharing this info
Thanks dmfor sharing your idea
Removing a wall in btw a house required a top notch expertise
Check if the wall is load-bearing (consult a structural engineer). Ensure no utilities (electrical, plumbing) are inside. Get permits and test for asbestos/lead in older homes. Non-load-bearing walls are safer to remove; load-bearing needs a support beam.
This is really a well done job
