The open-plan design has gained popularity with the current renovation projects around the world due to the maximization of the space, natural lighting, and the flow of space among the living areas. These vast arrangements, however, without a prudent staging, are likely to be undefined or oppressive. The secret of success is to make practical areas and retain the airy, open look.
Flooring and rugs are very effective in space definition during renovation. The living space can be divided by a huge rug under the sofa, and a contrasting rug under the dining table forms another eating space. The positioning of furniture is also significant. Arranging the sofas facing each other, or placing the shelving units and consoles as a small separator can help, as they allow defining the boundaries without secluding the space.
Another important component is lighting. Pendant lights over dining tables, floor lamps in living rooms, and recessed lights in all areas are used to bring the space together and at the same time make areas separate. Throughout the open-plan space, there is a good balance of color palettes, whereas accent colors or textures can be used to mark out certain zones.
Movement and flow should also be taken into consideration in the staging. Make walkways clean and make sure that the arrangement of furniture does not disrupt the natural walkways between spaces. Accent walls, artwork and large plants can be used as a point of focus and balance to pull the eye.
Conclusion: Open plans in renovation projects perform well when staging is concerned with flow and zoning and harmony. Through the wise application of the rugs, lighting and furniture arrangement, renovators are able to emphasize functionality without compromising the space, which leads to interiors that are harmonious, utilitarian, and aesthetically pleasing.
