Optimal mirror placement in a home
Mirrors are a versatile addition to any home, helping to amplify natural light, create the illusion of more space, and add decorative flair. Here are some of the best positions to place them, based on practical design principles and expert advice.
Entryway or Foyer
Hanging a mirror near the front door or in the entryway allows you to check your appearance before heading out and can make the space feel more welcoming. Position it perpendicular to the door to avoid directly facing it, which some traditions like Feng Shui suggest can repel positive energy. For optimal light reflection, place it opposite a window or light source in this area.
Bathroom
One of the most functional spots is above the sink or vanity in the bathroom. Mount it at eye level—about 60 inches from the floor—to ensure it’s usable for daily routines like grooming. This placement also helps brighten the often windowless space by reflecting artificial light.
Living Room
In the living room, consider placing a large mirror above the couch, fireplace mantel, or opposite a window to bounce light around and make the room feel larger. Avoid positioning it directly across from cluttered areas, as it will double the visual chaos. This spot works well for both aesthetics and functionality in social spaces.
Bedroom
For bedrooms, a full-length mirror near the closet or dressing area is ideal for outfit checks. If using a smaller one, hang it above the bed or dresser, but steer clear of placing it directly facing the bed, as it might disrupt sleep according to some beliefs. Ensure it’s at eye level for comfort.
Dining Room
Position mirrors on dining room walls to reflect the table, enhancing the sense of abundance and making gatherings feel more spacious. Placing one opposite a window or chandelier can also amplify light during meals.
Hallways or Small/Dark Rooms
In narrow hallways or dimly lit areas, mirrors can create depth and brightness. Hang them at the end of a corridor or opposite windows to reflect light and views, opening up the space visually.
General tips: Always secure mirrors properly to walls, especially heavier ones, and consider the room’s overall decor to ensure they complement the style.
Avoid kitchens (where they might reflect mess or heat sources) and direct opposition to beds or toilets for better energy flow.
Nice piece of information
well detailed article
Well written, very insightful
Simple but it definitely caught my attention
This article communicates its points without pressure
The work looks controlled.
