Priming is often seen as an extra step, but professional painters stress that it’s an investment that saves homeowners money in the long run. A quality primer creates a uniform surface that allows paint to adhere properly, reducing the number of coats needed. Without it, paint can soak unevenly into surfaces especially porous ones like new drywall or bare wood leading to patchy coverage and the need for costly touch-ups.
Primer also blocks stains, tannins, and old paint colors from bleeding through, which prevents rework and ensures the topcoat looks clean and vibrant. On tricky surfaces such as metal, glossy finishes, or masonry, specialized primers help paint bond better, reducing the risk of peeling or chipping later.
By extending the lifespan of a paint job and lowering maintenance costs, priming ultimately protects both the finish and the homeowner’s budget. Skipping primer may seem like a shortcut, but it often results in higher expenses down the line
