Painting as a life
Mistakes to Avoid while painting
Painting seems simple, but there are easy mistakes that ruin the result.
The biggest mistake is skipping primer paint might look fine at first, but it won’t stick properly and will peel within months.
Another mistake is using the wrong finish in the wrong room.
For example, flat paint in bathrooms is a disaster because moisture will stain it quickly.
I once made that mistake and had to redo the whole wall in satin finish, which resists water better.
Also, never overload your roller with paint because it causes drips and uneven coats. The fix? Take your time with prep work. Good painting is 80% preparation, 20% painting.
So put in a lot of work and make it count and be proven
Thanks for the heads up
Thanks for the insight brother
This is a good information
Glad to come across this man
Wonderful article bro
This is helpful man keep it up
This is really great buddy
This is nice keep it up
Good work buddy nice work
