Peel-and-stick tiles are worth the hype in the right spots
:white_check_mark: Budget-friendly, DIY-easy, renter-friendly, and great for quick updates in low-traffic, dry areas (backsplashes, laundry rooms, accent walls).
:cross_mark: They don’t last as long as ceramic/porcelain, can peel in moisture or high-traffic areas, and sometimes look “cheap” up close.
Bottom line: great for temporary or budget makeovers, but not a permanent solution for wet or busy spaces.
Aright, simple and understandable
Thanks for sharing this man
Brief and insightful
Such a good article Michelle
Glad you like it, thanks
