Clearing Blockages Quickly. A plumber’s snake is a flexible coil used to remove clogs from drains and pipes. It can navigate twists and turns that other tools cannot reach.
To use a plumber’s snake, feed the coil into the drain until you reach the blockage.
Turn the handle to break up or grab the clog, then pull it out carefully. It saves time and avoids harsh chemicals while keeping pipes clear.
