Quick Guide: Installing Smart Light Switches
Step 1: Turn Off Power
Go to your circuit breaker and switch off the power to the light you’ll be working on. Safety first!
Step 2: Remove Old Switch
Unscrew the wall plate, then carefully disconnect the existing switch.
Step 3: Identify Wires
You’ll usually see line (power), load (to the light), neutral (often white), and ground (green or bare). Make sure you know which is which.
Step 4: Connect Smart Switch
Attach the wires to the smart switch according to the instructions—line to line, load to load, neutral to neutral, ground to ground.
Step 5: Secure and Mount
Push the wires neatly back into the box, screw the smart switch in place, and reattach the wall plate.
Step 6: Restore Power
Turn the breaker back on and test the switch.
Step 7: Set Up App
Download the manufacturer’s app, connect your switch to Wi-Fi, and finish setup.
:white_check_mark: Done: You now have smart lighting that can be controlled by app, schedule, or even voice assistants.
I’ll be able to do this myself
Sure, you will be able to do thaat
Thanks for the instructions
Great instructions, thanks for that.
Thanks for your approval
Going through this made know that I can be able to fix myself
I should be able to try this myself with this guide
Thanks for the guide :smiling_face:
Can be able to do this now :grinning_face_with_smiling_eyes:
I will be able to this by myself
Thanks for sharing , keep it up
Glad to come across this
This is so interesting to read
