Refacing Kitchen Countertops with Concrete
You can upgrade countertops with a DIY concrete overlay, improving your kitchen ambience and aesthetics.
Clean existing countertops thoroughly and sand lightly. Mix concrete overlay and apply a thin layer with a trowel, smoothing evenly. Let it cure for 24 hours, then sand for a polished finish. Apply a second layer if needed, then seal with a food-safe sealant. This two-day project costs $100-$200.
The result is a modern, durable surface that mimics high-end concrete counters. With careful application, you’ll transform your kitchen’s look for a fraction of replacement costs. This could be a budget friendly activity and also beginner friendly, as it requires little expertise and could serve as fun activity that could be done alone or with friends.
You are always on point
This is very insightful
Renovation is an investment that pays off both in comfort and resale value.
Thank you very much for this inspiring words
I love this wonderful article bto
Keep up the good work mate
Incredible before & after!
Thank you for this info
