# How to Renovate Your Roof and Compound with DIY
Renovating your roof and compound yourself can save money and give you a sense of accomplishment.
The key is **planning well, staying safe, and working step-by-step**.
DIY Roof Renovation
### 1. **Inspect the Roof**
- Look for missing or cracked shingles, rust spots (for metal roofs), or leaks.
- Check gutters for clogs or damage.
### 2. **Clean the Surface**
- Use a roof-safe cleaner to remove moss, algae, and dirt.
- A soft brush or low-pressure washer works best to avoid damage.
### 3. **Repair or Replace Damaged Areas**
- For shingles: Replace missing or broken ones.
- For metal roofs: Patch rust spots and repaint with weatherproof paint.
- Seal small leaks with roofing sealant.
### 4. **Repaint or Reseal**
- Use UV-resistant, waterproof paint or sealant to extend your roof’s life.
**Safety Tip:** Always use a sturdy ladder, wear non-slip shoes, and never work on a wet roof.
DIY Compound Renovation
### 1. **Clean and Clear**
- Remove weeds, trash, and debris.
- Sweep pathways and pressure-wash driveways.
### 2. **Repair the Floor or Pavement**
- Fill cracks in concrete.
- Replace broken tiles or stones in walkways.
### 3. **Repaint Walls and Gates**
- Sand rough spots, apply primer, then paint with weatherproof exterior paint.
### 4. **Add Greenery**
- Plant flowers, shrubs, or even a small vegetable garden.
- Use potted plants if space is small.
### 5. **Upgrade Lighting**
- Install solar garden lights or LED fixtures to improve safety and beauty.
**Bottom Line:**
You don’t need to hire a big crew to breathe new life into your roof and compound.
With the right tools, patience, and a little creativity, your home can look brand new—all from your own effort.
