Renovation Maintenance After Installing Granite Countertops
Installing granite countertops can be a fantastic way to enhance the look and functionality of your kitchen. However, to ensure they remain in great condition, regular maintenance is essential.
Daily Maintenance
  1. Clean spills immediately: Clean spills immediately to prevent them from penetrating the stone.
  2. Use a mild cleaner: Use a mild cleaner specifically designed for granite countertops.
  3. Avoid harsh chemicals: Avoid using harsh chemicals, abrasive cleaners, or scouring pads, which can damage the granite surface.
Weekly Maintenance
  1. Dust and wipe down: Dust and wipe down the countertops with a soft cloth to remove any debris or dust.
  2. Check for stains: Check for stains or spills that may have penetrated the stone and clean them promptly.
Periodic Maintenance
  1. Seal the granite: Seal the granite countertops periodically to protect them from stains and spills.
  2. Deep clean: Deep clean the countertops periodically to remove any stubborn stains or grime.
Tips and tricks for Long Term Maintenance
  1. Avoid heat damage: Avoid placing hot pans or dishes directly on the granite surface.
  2. Use cutting boards: Use cutting boards to prevent scratches and damage from knives and other sharp objects.
  3. Avoid acidic substances: Avoid exposing the granite surface to acidic substances like citrus or vinegar.
Regular maintenance is essential to keep your granite countertops looking their best.
This really is an amazing work
Wow this is amazing bloke
Thanks for the heads up mate
This is really insightful thanks for sharing this information
Wonderful points my bro
Thanks for sharing this here
