Renovation Questions
How do you handle dust noise and disruption during home renovations and what strategies keep living spaces manageable and your sanity intact
Separate the construction from your daily life as much as possible, protect your space, and schedule time for yourself to avoid feeling overwhelmed.
You must first know how to separate all things differently
To handle dust, you might use plastic sheeting to seal off renovation areas, employ air purifiers, and clean regularly. For noise, consider scheduling work during times when it’s less disruptive or using noise-canceling headphones. To keep your sanity, try setting up a temporary living space away from the renovation zone and maintaining a routine. These strategies can help make the renovation experience more manageable and less stressful.
You are making sene here
