When renovating a fireplace how do you balance safety aesthetics and functionality and what upgrades make it a central feature without compromising structure
Plan heating, cooling, and ventilation together so systems work efficiently as one. Small upgrades like sealing air leaks, adding insulation, installing ceiling fans, or using smart thermostats boost comfort, save energy, and improve usability.
To make the fireplace a central feature without compromising its structure, you might add elements like a striking mantelpiece, built-in shelving, or accent lighting. These upgrades can draw attention to the fireplace while maintaining its integrity and safety.
Ensure safety first by inspecting the chimney, firebox, and venting. Choose materials and design that match your home, and consider heat-efficient inserts or gas conversions for better function. Upgrades like a new mantel, stone or tile surrounds, or built-in shelving make the fireplace a stylish, safe focal point.
First ensure your safety tool box is complete
Thanks for sharing this out
