Small rooms can feel cramped, but clever renovation strategies make them appear more spacious. Start with light, neutral wall colors, which reflect light and open up the space. Mirrors are a classic trick that adds depth while doubling as décor.
Flooring continuity is key. Using the same flooring throughout adjoining rooms creates a seamless flow that tricks the eye into seeing a larger area. Avoid heavy, dark furniture that overwhelms a compact space.
Quirky tip: paint the inside of door frames a slightly lighter shade than the walls. This subtle technique gives the illusion of more space and draws the eye upward.
Lighting is another game-changer. Layered lighting with ceiling lights, wall sconces, and task lamps eliminates shadows that shrink a room. Homeowners in Australia and New Zealand often pair this with energy-efficient LED fixtures to save on utility bills.
Small rooms benefit from multifunctional furniture. Think fold-out desks, ottomans with storage, or wall-mounted tables. Even minor adjustments can dramatically improve both functionality and visual appeal.
