Restrooms and utility areas for clubs and supermarkets are areas with high moisture levels and require careful attention when expanding. Proper waterproofing for durability and safety and hygiene.
In restrooms, water from the sinks, toilets and cleaning can seep into the floors and walls if unchecked. Waterproof membranes, moisture resistant tiles, and closed joints, that prevent leaks and mould growth. This not only helps protect the structure, but also helps keep the environment clean and healthy for customers and staff.
Utility rooms - rooms housing HVAC, plumbing or electrical equipment also need to be waterproofed. Spills, condensation or small leaks might damage sensitive machinery or cause hazards. Waterproof coatings, sealed floors and elevated platforms keep equipment safe and save on long-term maintenance expenses.
In addition to being protective, waterproofing is an aesthetic and longevity factor. Properly sealed spaces retain their finish for longer periods of time, requiring less frequent repairs or repainting. In clubs, polished waterproof flooring provides a stylised modern appearance, whilst standing up to spills and high traffic levels.
Waterproofing is required in areas subject to high moisture. By investing in membranes, resistant finishes and smart design, clubs and supermarkets have restrooms and utility spaces that are functional and safe while also looking nice. Proper waterproofing aids in both customer comfort as well as operational efficiency, and is a key component for successful expansion.
