Safety Focus: Ladder Setup Mistakes That Cause Accidents ⚠️
Ladders may seem simple, but improper use is a major cause of home and workplace injuries. Here’s what to watch out for to stay safe.
:prohibited: Common Ladder Setup Mistakes
  1. Wrong angle – Ladders that are too steep or too shallow can tip. The ideal angle is roughly 75° (1 foot out for every 4 feet up).
  2. Uneven ground – Setting a ladder on rocks, mulch, or slopes can make it wobble. Always use a stable, level surface.
  3. Overreaching – Leaning too far sideways causes falls. Move the ladder instead.
  4. Ignoring weight limits – Every ladder has a maximum load—don’t exceed it.
  5. Top-step temptation – Standing on the top rung or step often leads to loss of balance.
:hammer_and_wrench: Safety Tips
  • Inspect the ladder before each use for cracks, bent parts, or missing feet.
  • Wear slip-resistant shoes.
  • Keep the ladder free from oil, paint, or debris.
  • Always maintain three points of contact (two hands and one foot, or two feet and one hand).
:white_check_mark: Bottom Line
Most ladder accidents happen because of simple setup mistakes. A few careful steps and awareness can prevent serious injuries and keep your projects safe and stress-free
Thanks fr the great insight :+1:
Safety is the topmost priority in renovation and shouldn’t be toyed with :palms_up_together:t5:
Safety is really important we should not overlook that
You welcome and don’t forget to make use of the safety tips
Prevention is better than cure
This will help a lot
Thanks for sharing
Safety first over every other thing
Thanks a lot fam
