Should gutter guards overlap?
Should gutter guards overlap during installation? If so, what method should I use?
Yes, gutter guards should overlap during installation to ensure proper coverage and prevent debris from getting into the gutters. You should use the “shingle method” to overlap, where each next guard panel overlaps the previous one by a few inches. This creates a barrier that water can flow through, while keeping leaves and other debris out. Always check manufacturer guidelines for specific recommendations on overlap!
