Should I choose cement board or foam backer boards for showers with linear drains?
For showers with linear drains, foam backer boards are generally the better choice due to their waterproof properties, lighter weight, and ease of shaping for proper slope, while cement boards are more durable but require a separate waterproofing layer and are harder to shape around linear drain systems.
The choice between cement board and foam backer board depends on your specific needs, the design of your shower, and the requirements of your project. It’s essential to consult with a professional to determine the best option for your situation.
For showers with linear drains, both cement board and foam backer board work, but foam boards (like Wedi or Schluter Kerdi-Board) are lighter, easier to cut, and already waterproof, which speeds installation.
Cement board is cheaper and very sturdy but needs a separate waterproofing membrane and is heavier to handle. With linear drains where precise slope and waterproofing are critical foam boards often make it easier to achieve consistent pitch and reduce risk of leaks.
Cement board is tough and costs less, but it’s heavy and needs extra waterproofing. Foam board is light, waterproof, easy to cut, and quicker to install, but it’s pricier. For linear drains, foam boards are often easier to waterproof and install.
Yeah, it’s true
Definitely a good renovation idea
