Should I get gutter guards?
Gutter guards can be a worthwhile investment, especially if you live in a heavily wooded area. They reduce the frequency of gutter cleaning, but they don’t eliminate it entirely.
When considering gutter guards, here are some key points to keep in mind:
Cost vs. Benefit: Gutter guards can range from $1,000 to $2,500, depending on the type (like stainless steel plates or mesh filters). Regular gutter cleaning typically costs around $150 twice a year. Calculate how much time and money you’ll save in the long run.
Maintenance: Even with guards, you may still need to clean your gutters occasionally, especially if you have trees nearby shedding leaves and debris. Some homeowners find that guards make it harder to access the gutters for cleaning, so consider the design and ease of maintenance.
Types of Guards: There are various styles of gutter guards available. Some are designed to handle larger debris, while others focus on smaller particles like pine needles. Choose a type that suits your specific environment.
Warranty Considerations: Some companies offer warranties that cover cleaning and maintenance, which can be a significant benefit. Be sure to read the fine print before making a decision.
User Experiences: Many homeowners report mixed results with gutter guards. Some feel they are helpful, while others find they still need to clean their gutters regularly. It’s beneficial to check community forums or Reddit threads for real-life experiences and recommendations.
Ultimately, whether to install gutter guards depends on your specific needs, the environment around your home, and your willingness to maintain them. If you’re unsure, consulting with a local home improvement expert can provide tailored advice.
