Adding wall shelves is a practical and stylish DIY project that increases storage and displays items beautifully
Measure and mark the wall Carefully measure the space and mark where each shelf will go Using a level ensures straight placement
Choose the right materials Wood planks, brackets, and screws are the basics Select materials that match your room style and load requirements
Install securely Attach brackets to studs for stability Place the planks on top and secure with screws Double check alignment and weight support
Final thought DIY wall shelves show that small projects can transform a room Efficient measuring, proper materials, and secure installation create functional and attractive storage
