Solar System Protection Checklist During Renovation
1. Pre-Renovation Planning
- Identify all solar panels, inverters, and battery locations.
- Communicate the solar setup to contractors and electricians.
- Schedule work to minimize disruption to active solar components.
2. Power Shutdown
- Turn off solar breakers before starting electrical or roofing work.
- Ensure main panel and inverter switches are safely disconnected.
3. Physical Protection
- Cover solar panels with protective materials if construction debris is likely.
- Use scaffolding or barriers to avoid accidental impact.
4. Wiring & Connections
- Inspect all wiring for wear or loosened connectors before work begins.
- Label and map all solar-related circuits to avoid accidental disconnection.
5. Battery & Storage Care
- If using a battery, disconnect it to prevent overcharging or damage.
- Monitor charge levels and avoid draining during work.
6. Post-Renovation Checks
- Reconnect circuits carefully and turn breakers back on.
- Inspect inverter for error codes and verify solar output.
- Clean panels if any dust or debris accumulated.
7. Professional Oversight
- Hire a qualified electrician familiar with solar systems for any major electrical modifications.
- Keep documentation of all changes for warranty or insurance purposes.
Tip: Always plan renovations around solar exposure and energy needs—sometimes temporary energy solutions (generators or grid reliance) may be safer during construction.
