Basements are often multipurpose spaces - home theatre, music room, office, guest bedroom, etc. But without the right soundproofing, noise coming from upstairs can leak down and the conversation happening in the basement can easily disrupt the rest of the house. The choice of the right soundproofing materials assures peace, privacy, and comfort.
Acoustic panels are one of the easiest solutions. Installed on walls or the ceiling, they absorb sound waves and minimise echo. This is because they are ideal in building relaxing and soothing environments.
For more of a structural approach, you can add soundproof drywall or double-layered walls for greater noise control. These materials have been made with special cores that block the transmission of sound. Pairing them with insulation on the inside of wall cavities increases their performance.
Floor underlayments are also a factor. Rubber or cork underlayment, placed underneath flooring, to absorb vibrations, preventing footsteps or music from travelling through the structure.
For ceilings, resilient channels make a good choice. They separate drywall from framing and this minimises the direct transfer of noise between floors. Combined with acoustic insulation, they form a sound barrier of great strength.
Soundproofing makes a basement a real retreat - for relaxation, entertainment or productivity. With the right materials such as acoustic panels, specialised drywall and underlayments, homeowners can have quiet comfort below ground. Renovation is not just about making a basement look pretty - it’s also about making it peaceful.
