Working at heights is one of the most dangerous aspects of renovation, especially when climbing ladders, repairing roofs, or installing upper-level fixtures. A simple slip can result in life-threatening injuries. This is why safety harnesses and fall arrest systems are essential for any renovation project involving elevated work.
A safety harness is worn securely around the body and connected to an anchor point. If a worker slips, the harness distributes the force across the body, preventing serious injury. Fall arrest systems go a step further by including shock-absorbing lanyards or retractable lifelines that stop falls gradually, reducing strain on the body.
These tools aren’t just for professional construction crews—homeowners tackling DIY renovations on rooftops or scaffolding can benefit from them as well. They provide peace of mind, knowing that a single mistake won’t lead to disaster.
Using a harness properly is just as important as wearing one. The anchor point must be strong, and the straps fitted correctly to avoid slipping. Combined with guardrails and secure ladders, harnesses and fall arrest systems create a safer work environment where risks are controlled.
