Step by step guide on how to fix a 3D wallpaper
‎Here’s a clear step-by-step guide on how to fix (install) 3D wallpaper, plus the materials you’ll need. This works for most 3D wall murals, PVC 3D wallpapers, and embossed designs.
‎🧰 Materials & Tools Needed
‎3D wallpaper (measure your wall first)
‎Wallpaper adhesive (or pre-pasted glue if specified)
‎Clean bucket
‎Paint roller or wallpaper brush
‎Plastic smoothing tool / squeegee
‎Measuring tape
‎Pencil
‎Spirit level or plumb line
‎Utility knife / sharp cutter
‎Soft cloth or sponge
‎Step ladder
‎Sandpaper (fine grit)
‎Wall filler
‎Step by Step Installation Guide
‎Step 1: Prepare the Wall
‎Remove old wallpaper, nails, or peeling paint
‎Fill cracks or holes with wall putty
‎Sand the wall smooth
‎Clean off dust and grease
‎Make sure the wall is dry, smooth, and flat
‎note: A smooth wall is very important for 3D effects to look real.
‎Step 2: Measure and Plan
‎Measure wall height and width
‎Lay the wallpaper on the floor to understand the pattern
‎Mark a straight vertical line on the wall using a level (starting guide)
‎Step 3: Apply Adhesive
‎If the wallpaper is NOT self-adhesive:
‎Mix wallpaper glue as instructed
‎Apply glue evenly on the wall (or wallpaper back, depending on type)
‎Don’t over apply to avoid bubbles
‎If it’s self-adhesive:
‎Peel off backing slowly as you stick it to the wall
‎Step 4: Fix the Wallpaper
‎Start from the top of the wall
‎Align the first sheet with your straight guide line
‎Press gently from top to bottom
‎Use a squeegee or brush to smooth out air bubbles
‎Work from the center outward
‎Step 5: Match the 3D Pattern
‎Carefully align the next sheet so the 3D design matches perfectly
‎Press edges firmly so seams are invisible
‎Continue until the wall is covered
‎Step 6: Trim Excess Wallpaper
‎Use a sharp cutter to trim edges at the ceiling, floor, and corners
‎Wipe off excess glue immediately with a damp sponge
Step 7: Final Check & Drying
‎Smooth remaining bubbles
‎Let the wallpaper dry for 24 hours
‎Avoid touching or cleaning during this time
‎✅ Pro Tips for Perfect Results
‎Install in good lighting to align the 3D pattern correctly
‎Always use a sharp blade to avoid tearing
‎Don’t rush, 3D wallpaper needs careful alignment
‎For large murals, install with two people
Thanks this is very well detailed
Excellent work keep it up bro
Thank you for sharing this
Thanks for the article, worth reading
Really nice article thanks
You are making sense bro
This is so impressive
