Want a new floor vibe without spending a ton? Vinyl flooring is a super easy and budget-friendly way to make your house look great. Guess what? You can totally do it yourself! ![]()
Whether it’s the living room, bedroom, or even the kitchen that needs a little love, I’ll walk you through how to put in vinyl flooring, one step at a time. Don’t worry if you’ve never done it before!
What You’ll Need
Before we get rolling, here’s what you’ll need:
Vinyl plank flooring or vinyl sheets
Utility knife
Tape measure
Straight edge (or ruler)
Pencil or chalk
Spacers
Rubber mallet
Tapping block (for click-lock planks)
Floor roller (not required, but can be useful)
Let’s Get Started
Step 1: Get the Floor Ready
- First, give the floor a good sweep and cleaning.
- It needs to be smooth and dry – get rid of any bumps, nails, or holes.
- Thinking of laying it over tile or concrete? Maybe use underlayment.
- Take off those baseboards or trims if you need to.
A clean, flat surface is key. It helps the vinyl stick better and last longer.
Step 2: Size Up the Room
- Time to measure! Get the length and width of the room.
- Do a little math to figure out how much vinyl you’ll need.
- Grab an extra 10% for mistakes or when you need to trim pieces.
Step 3: Sort out Your Plan
- Before you start sticking anything down, lay out a few planks.
- Try to start from the longest wall or the straightest side.
- Check that the last row won’t be too thin – if it is, cut the first row a bit.
Chalk lines are your friend here. They’ll help keep everything straight.
Step 4: Get to Laying!
Vinyl comes in two styles:
Peel-and-Stick / Glue-Down
Click-Lock (Floating) Planks
For Peel-and-Stick or Glue-Down:
- Just peel off the backing and press it down nice and firm.
- Smooth out any air bubbles that pop up.
- Roll a floor roller (or something heavy) over it to press it down evenly.
For Click-Lock Planks:
- These click together at the edges.
- Use a tapping block and rubber mallet to make sure they’re snug.
- Pop some spacers between the planks and the wall (it leaves room for things to expand).
Step 5: Cut as You Go
- When you hit a wall or corner, measure how much you have left.
- Draw a line where you need to cut with your pencil or chalk.
- Score it with a utility knife, and give it a snap.
Take your time around corners and doors. Try fitting the vinyl before you stick it down.
Step 6: Tidy up the Edges
- Take out all the spacers.
- Put those baseboards or trims back on to hide the gaps.
- Give the floor a sweep or mop, and stand back to admire your handiwork!
You Nailed It!
Putting in vinyl flooring yourself saves cash and freshens up your space. With a bit of patience and the right stuff, you can totally do this, even if it’s your first time.
Extra tidbit:
Vinyl floors? Easy to clean and they don’t mind water. So they’re great for bathrooms, kitchens, or if you’ve got kids and pets running around!
