Drafty windows don’t just make a room uncomfortable, they also increase energy bills. One of the simplest and most effective solutions is weatherstripping. By sealing the small gaps around your windows, you can block unwanted air leaks, keep your home more comfortable, and improve energy efficiency.
- The first step for weatherstripping a window is preparation.
- Begin by inspecting your windows closely.
- Look for areas where light peeks through or where you can feel air coming in.
Once you’ve identified the gaps,
- Clean the window frame thoroughly, removing dust and old adhesive so the weatherstripping sticks properly.
Next,
- Measure the length of the window edges that need sealing. Always measure twice to avoid cutting strips that are too short.
- Select the right type of weatherstripping for your needs
Examples are
ADHESIVE BACK FOAM TAPE
V-STRIP
FELT
Foam tape is easy to apply for small gaps, while V-strip provides a durable seal for frequently opened windows.
Once you’ve chosen your material
- Cut it to size with scissors or a utility knife.
- Peel off the backing if it’s adhesive, and carefully press it along the frame, making sure it’s straight and secure.
- For non-adhesive types, you may need tacks or small nails to hold the material in place.
After installation
- Test the window by opening and closing it to ensure a proper seal without restricting movement.
Weatherstripping is a quick project that pays off in comfort and savings. With just a little effort, you can transform drafty windows into energy-efficient barriers, keeping your home cozy in winter and cool in summer. It’s one of those small upgrades that makes a noticeable difference year-round.
