Steps on Renovating your home without breaking the bank
‎Here’s a clear, practical step-by-step guide to renovating a house on a low budget, focusing on high impact, low cost changes you can actually do
‎1. Make a Simple Renovation Plan
‎‎Before spending anything:
‎Walk through the house and write down what is broken and what looks old
‎‎Separate into:
‎‎Important things to fix (leaks, wiring, doors, safety)
‎‎Nice to have (paint color, decor, style)
‎‎Set a strict and realistic budget and add extra money for emergencies
‎‎Planning can help save you a lot of money.
‎2. Fix Structural & Safety Issues First
‎Do these first so you don’t redo work later:
‎‎Repair roof leaks
‎Fix plumbing leaks
‎Secure loose electrical sockets and old wires
‎‎Repair broken windows or doors
‎‎Tip: Small repairs now prevent expensive damage later.
‎‎3. Repaint or use wallpaper Instead of Rebuilding
‎‎Paint and wallpaper gives the biggest transformation for the lowest cost.
‎‎Use light colors (white, cream, light grey or 3D wallpaper) to make rooms look bigger and more attractive
‎Paint or spray old cabinets, doors, and wardrobes instead of replacing them
‎‎Refresh exterior walls if possible
‎Much cheaper than new installations.
‎4. Upgrade Floors the Cheap Way
‎‎Instead of replacing floors:
‎Clean and polish existing tiles with chemicals like oxygen bleach or hydrogen peroxide
‎Use vinyl tiles, laminate, or carpet rugs
‎Repair cracked tiles instead of retiling everything
‎Area rugs can hide floor imperfections.
‎‎5. Improve Lighting (Big Impact, Low Cost)
‎Replace old bulbs with LED bulbs
‎Add brighter bulbs to dark rooms
‎Clean light fixtures or spray paint them for a fresh look‎
Good lighting makes old spaces feel new.
‎‎6. Renovate Kitchen Without Full Replacement
‎Paint or spray kitchen cabinets instead of buying new ones
‎Change cabinet handles (very cheap, huge difference)
‎Spray boric acid or fipronil to kill termites or insects
Organize shelves to reduce clutter
‎Kitchen upgrades don’t have to be expensive.
‎‎7. Bathroom Refresh on a Budget
‎Replace shower curtain, mirror, and taps
‎Re-grout tiles instead of replacing them
‎Paint tiles using tile paint
‎‎Fix leaks immediately
‎Small bathroom changes feel luxurious.
‎‎8. Reuse, Repair & DIY Where Possible
‎‎Repair old furniture instead of buying new
‎‎Use second-hand items or local markets
‎DIY simple tasks like painting, installing shelves, or curtain rods
Labor costs often cost more than materials.
‎9. Decorate Smartly
‎Use mirrors to make rooms look larger
Add curtains, throw pillows, and wall art
‎Indoor plants add life and beauty cheaply
‎Simple decor upgrades go a long way.
‎10. Renovate in Stages
Don’t rush everything at once
Finish one room before starting another
‎Spread costs over time
‎This keeps your budget under control.
‎Budget-Saving Golden Rules
:check_mark: Repair before replacing
:check_mark: Paint changes everything
‎✔ DIY whenever safe
‎✔ Avoid unnecessary demolitions
‎✔ Buy only what you need
You are making sense here
You are on point brother.
This is very well detailed
Well detailed thank you
You’re making sense friend
