The roof renovation was coordinated to improve the overall comfort of the building. Inspection revealed that poor roofing conditions were allowing heat, moisture, and noise into interior spaces. Loose sheets and open joints were the main causes.
Renovation work was planned to correct these issues. Roofing sheets were properly secured, gaps were sealed, and alignment was improved. Attention was also given to ventilation and drainage to enhance indoor comfort.
I supervised each stage to ensure that materials were correctly installed and that the finished roof met the intended purpose. After renovation, indoor spaces became drier and more comfortable.
Supervising roof renovation with a focus on comfort improves building usability. Proper coordination ensures a roof that protects, insulates, and supports a better indoor environment.
