What Is Superwood?
Invented at the University of Maryland and now under commercial development by startup InventWood, Superwood is created by partially removing the lignin from natural wood and then compressing the cellulose under heat. The result:
• ~50% stronger than steel in terms of strength-to-weight ratio
• Class A fire resistance, termite- and rot-resistant when treated
• Durable in long‑term aging tests, resisting fungal decay
Mass‑scale production is scheduled to begin in mid‑2025, initially targeting exterior cladding, façade panels, furniture, and potentially structural components
Why Superwood Matters for Home Renovation
- Ultra‑strong and lightweight
Its outstanding strength and lighter weight make it ideal for retrofits where structural load is a concern—allowing thinner supports or bold design elements like cantilevers, cantilevered shelving, beams, or exterior overhangs.
- Eco-friendlier than steel or concrete
Because it starts from renewable wood, Superwood benefits from carbon sequestration during growth and has a much lower embodied carbon footprint compared to traditional metals or cement. It gives you structural performance with sustainability.
- Fire and insect resistance built-in
Conventional wood requires chemical treatments or cladding to meet fire or pest-resistant standards. Superwood brings inherent resistance via its compression process and polymer infusion.
- Durability without maintenance
Unlike traditional wood which may crack, warp, or decay, Superwood is engineered to resist moisture and biological degradation, reducing the need for regular maintenance or replacement over decades.
How Could You Use It in Renovation
• Exterior cladding and façade upgrades: Replace aging fibre‑cement or vinyl siding with durable, lightweight aesthetic panels.
• Structural components in remodels: Use Superwood beams for supporting roof overhangs, mezzanine floors, or open-wall interiors.
• Built-in furniture and cabinetry: Add sleek, strong, eco‑friendly permanence to built-ins.
• Deck or porch surfaces: Waterproof, rot‑resistant decking that remains visually warm and natural.
Beyond the Conventional: How it compares
| Feature | Conventional Wood | Concrete / Steel | Superwood |
| Strength‑to‑weight | Moderate | High | Very high |
| Durability | Prone to rot, pests | Long-lasting but heavy | Inbuilt decay resistance |
| Fire / decay resistance | Requires treatment | Inherent (steel, concrete) | Built-in fire rating |
| Carbon footprint | Moderate | Very high | Lower than steel |
| Maintenance | Frequent upkeep | Low | Minimal |
Emerging Alternatives
There are other promising materials in the pipeline too:
• Self‑healing concrete: Embeds bacteria or microcapsules that repair cracks automatically, extending lifespan
• Phase-change materials (PCMs) and aerogel‑infused insulation: Passive thermal regulation inside walls and panels to reduce HVAC needs
• Transparent wood composites: Clear or translucent versions of engineered wood for eco‑glass alternatives—with insulation and light diffusion benefits
Why It Matters – From Contractor to Homeowner
Future-proofing: Lower long‑term maintenance, high resistance, and durability reduce lifetime cost.
Design frees creativity: Stronger, lighter materials let you rethink spatial layouts or visual dynamics in renovations.
Sustainability advantage: Renewable, low‑carbon, and recyclable—Superwood aligns with eco-conscious design trends.
Thermal & aesthetic gains: Natural wood appeal without compromises in performance.
What’s Next?
• Look out for commercial availability in 2025—initially via façade and cladding vendors.
• Pilot it on exterior or structural applications, where its strengths shine.
• Collaborate with architects or engineers, to assess load-bearing uses or integrate in renewable façade design.
• Pair it with passive systems like phase-change walls or self-cleaning coatings for eco-resilience.
In Summary
Superwood is a high-performance engineered timber that is stronger than steel, environmentally friendly, and extremely durable. As it becomes commercially available later this year, it offers a compelling future-facing option for homeowners and renovators seeking sustainable strength, lightweight yet robust renovation materials, and a lower carbon footprint. Although not yet mainstream, its properties and upcoming release make it one of the most exciting materials to watch—and plan for—in home renovation.
