Sycamore is a hardwood that has a pale colour, fine grain, and is versatile and this makes it an ideal choice in cabinetry. Sycamore cabinets, when combined with granite counters and wall extensions, form a kitchen or work area that is both strong and durable as well as beautiful.
The sycamore is very light and creamy giving a clean and modern appearance which illuminates interiors yet granite is a contrast to this because of its coarse veining and solid surface. This combination is particularly successful in the kitchen, where sycamore matches the grandiose designs of granite with its slight grain. When granite is extended on countertops to the walls, the flow of the surfaces becomes complete and the surfaces are united in terms of utility and beauty.
Sycamore cabinets are practically robust, stable and not prone to daily wear hence can be used in storage heavy settings. Wall extensions and granite counters are durable, heat-resistant, and help to avoid stains, scratches, and spills on surfaces. The combination of these two features is a very robust design solution that can survive the test of time and still have a classic feel of style. The contrast between lightness of sycamore and darker colours of granite is emphasised by designers with the help of the lights, which make the space even deeper and richer.
Conclusion:
The combination of sycamore cabinets, granite counters and extensions of the walls provides an ideal functionality and style balance. Not only does this combination of wood and stone guarantee durability over time, but also gives interiors a classic and seamless look. Sycamore and granite provide a stable solution to the needs of the homeowners and remodellers who would need their kitchens and work areas to be more practical and at the same time appealing to the eye.
