Precision for Large Projects
A table saw is a stationary power tool with a circular blade mounted on a table, allowing precise and straight cuts on large pieces of wood. It is ideal for cutting boards, panels, or furniture components.
To use a table saw, set the blade height slightly higher than the material thickness and align the wood with the fence. Push the material steadily through the spinning blade using both hands or a push stick for safety. Table saws are perfect for making long, accurate cuts quickly and are a staple in woodworking and renovation workshops.
