When you have felt an old single-pane window in a cold morning, you may imagine how much a heat they conduct out of it. And that is where the concept of double glazing comes in; an inexpensive concept that creates a big difference in the way a home is felt and operated.
The double-glazed windows consist of two layers of glass with a void between them which is usually filled with air or a gas of low density such as argon. That insulation is a barrier, which retards transfer of heat. During winter, it assists in keeping the warmth in the house; during summer it prevents much of the external heat. The result? You save on an overtime use of your heating and cooling systems in rooms.
The only advantage is that it is comfortable. There is also the benefit of double glazing, of cutting down the noise of the outside world, which can come as an actual blessing, when you are living by traffic or in a high-paced area. It is one of those upgrades that you may not realize until you have it and you wonder how you ever used to live without it.
Saving of energy is another advantage. Saving on heating and cooling costs is truly worth a lot in long-term perspective, so this renovation will pay itself in the long-term. And since modern day, the double-glazed windows are available in a large range of designs and different finishes, you do not need to sacrifice on the looks in order to achieve the performance.
In a word, double glazing belongs to a category of such practical extensions as enhancing the comfort level, reducing expenditures, and even increasing the house price. Not flashy but it brings daily living much better, which is precisely what good renovating work is supposed to do.
