Basement renovations often go wrong when homeowners skip proper waterproofing, leading to moisture buildup, mold, and damaged finishes. Covering damp walls with drywall or carpet is a common mistake.
The Fix:
Moisture problems should be addressed at the source. Installing a sump pump, dehumidifier, or drainage system may be necessary. Affected walls should be stripped, cleaned, and sealed with waterproof coatings before refinishing. Moldy materials must be removed safely to protect health.
Prevention:
Before renovating, basements should undergo a moisture test. Using water-resistant materials such as vinyl flooring, treated wood, and moisture-safe insulation ensures long-lasting results.
In conclusion, basement fails often start hidden but can be devastating. Addressing water issues first guarantees a safe, usable space.
