Ceilings are often overlooked in renovations, but cracks, sagging, or poorly finished drywall seams can ruin a room’s appearance. These problems typically arise from poor installation, water damage, or structural movement.
The Fix:
Small cracks can be repaired with joint compound and mesh tape, followed by sanding and repainting. For sagging ceilings, it’s crucial to identify the cause whether water leaks or weak framing before reattaching drywall or replacing damaged sections.
Prevention:
Using moisture-resistant drywall in bathrooms and kitchens prevents sagging. Properly securing sheets with screws rather than nails reduces future separation. Regular inspection for roof or plumbing leaks also keeps ceilings intact.
In conclusion, ceiling fails are often signs of deeper issues. Quick fixes help temporarily, but long-term solutions require proper materials and installation techniques.
