Okay, so you’re thinking about screwdrivers, huh? Let’s talk about them.
First off, there’s the standard, old-school manual screwdriver. It’s the one we all know. You grab the handle, twist, and the screw goes in (or comes out!). It’s super basic, which also makes it super dependable. For those little, I just need to tighten this one screw moments, it’s perfect. Simple as can be.
Now, if you’re dealing with more than just a screw or two, or if you’re stuck in a spot where it’s tough to move your hand around, a ratcheting screwdriver is your friend. These things have a cool gear thing inside that lets you twist and twist without ever lifting up. Seriously, it makes the job so much easier. You can switch it so it tightens, loosens, or stays put. Trust me, if you’ve got a bunch of screws to handle, or you’re working in a cramped space, this type of screwdriver will save you a ton of time and energy.
So, here’s the lowdown: If it’s a quick, easy job, stick with the manual screwdriver. But if you want to get things done quicker and with less fuss, I would recommend going with a ratcheting screwdriver, especially when you are dealing with lots of screws or awkward spots. I think you can choose one that best suits you.
