A common renovation fail is ending up with doors that don’t close properly, stick to the frame, or swing open on their own. These issues often happen when frames aren’t leveled correctly during installation, or when settling occurs afterward.
The Fix:
Minor misalignments can often be corrected by adjusting the hinges or sanding down tight edges. For sticking doors, trimming the bottom or sides slightly can restore smooth movement. If the frame itself is uneven, reinstalling or shimming it may be necessary.
Prevention:
To avoid door fails, renovators should always use a level and shims during installation. Leaving a small gap between the door and floor prevents swelling-related issues in humid environments. Choosing high-quality hinges also ensures durability.
In conclusion, door problems are frustrating but easy to fix with patience and precision. With proper planning, doors can open and close smoothly for years.
