Mirrors have been considered to be the most powerful in interior staging, particularly in the process of renovation. They do not just reflect images, they can increase the natural light, make the illusion of bigger spaces, and provide a decorating touch to interior. In rooms that appear too small or dark, mirrors should be placed strategically to change the whole mood.
When renovating, look into having mirrors facing the windows or the source of light to reflect sunlight all over the room. The method maximises light and makes the room look spacious and airy. Full length / floor to ceiling mirrors may give an illusion of height and wall mounted mirrors above furniture such as consoles or sofas provide depth and dimension. Even decorative mirrors even a little can be put together in an ingenious way to enlarge a tight passageway or a small area.
Mirrors are also useful design elements. In the modern renovations, smooth frameless mirrors give a minimalistic effect of a clean surface and fancy mirrors with ornate frames give character and beauty. They also may serve as the centres of attention, focusing on particular parts of a room or supplementing the arrangement of artwork and furniture.
However, placement is key. Mirrors should not be cluttered around the walls, and the placement needs to be so that it reflects something unattractive. The thoughtful mirror does not only enrich the perception of space of the room but also catches the finest aspects of a new space after renovation.
Review: Mirrors are a clever idea to use in the renovation process to increase the amount of light and make the room seem open. Mirrors used in a wise way can add a high level of aestheticism, improve functionality, and create the impression of spaciousness, welcome, and beauty in even small or dark spaces.
