DIY projects are empowering, but electrical work is where many homeowners stumble. Small errors can lead to safety hazards or costly repairs later on.
Mistakes to avoid:
Overloading Circuits: Plugging too many devices into one outlet can trip breakers or worse.
Wrong Wire Size: Using an undersized wire for high-load appliances creates fire risks.
Loose Connections: Poorly tightened screws in outlets cause sparking and heat.
Skipping Permits: Even small changes often require approval for safety compliance.
Ignoring Grounding: Without grounding, the risk of electrocution rises significantly.
Conclusion: Unless you’re confident and informed, leave major electrical work to professionals. A small “saving” today can cost far more tomorrow.
