Open concept layouts are popular, but many homeowners make the mistake of removing load bearing walls without proper support. This can cause sagging ceilings, cracks, or even structural collapse.
The Fix:
If damage has already occurred, the solution is to reinforce the structure. Installing beams or columns, preferably designed by a structural engineer, restores stability. In severe cases, jacks may be used to re-level floors and ceilings before adding permanent support.
Prevention:
Before removing any wall, it’s essential to consult an engineer or licensed contractor. Load-bearing walls can often be replaced with engineered beams that maintain open space without compromising safety.
In conclusion, cutting corners with wall removal can be disastrous. Proper planning ensures that an open layout is both safe and stylish.
