Poor plumbing work during renovations often leads to slow leaks, low water pressure, or noisy pipes. These issues usually occur from improper fittings, failure to test systems, or using incompatible materials.
The Fix:
Leaks should be addressed immediately by tightening or replacing faulty connections. For larger problems, such as corroded pipes, replacement is often the best solution. Installing shut-off valves near sinks and toilets provides added control.
Prevention:
To prevent plumbing fails, renovators should always pressure-test systems before closing walls. Using high-quality fittings, proper sealants, and the correct pipe materials for each application ensures longevity. Consulting a plumber for complex jobs avoids costly mistakes.
In conclusion, plumbing mistakes can be hidden but dangerous. Careful testing and professional oversight prevent water damage and costly repairs.
