One of the most frustrating renovation fails is a roof that still leaks after a costly repair. This usually happens due to poor flashing installation, improper shingle placement, or overlooked structural issues.
The Fix:
The first step is to trace the leak to its source, which is often not directly above the water spot indoors. Replacing damaged shingles, reapplying flashing, or sealing gaps with roofing cement may solve small issues. For major leaks, sections of the roof may need replacement.
Prevention:
Roofing projects should always include high-quality underlayment, flashing, and waterproof barriers. Hiring experienced roofers and performing regular inspections reduces the risk of post-renovation leaks.
In conclusion, roof fails are costly but preventable. Careful installation and quality materials protect the home for decades.
